Papotto
[L40 Ultra AE] Command automatization
I would like a command that i set up into the app (mop after vacuuming) to be executed at a specific time. Now im not able to do it. the only action that I can schedule at a specific time is a "global cleaning".
Hello, the cleaning schedule can be customized in every aspect: room one mop only, room two vacuum while mopping, etc. To do this, go to Settings, Scheduled Cleaning, and select Customize. From there, you can personalize the cleaning for each room. If I understood your request correctly, I’ve attached a GIF showing how to do it. I hope this was helpful.
Può trovare l'opzione "Programma di pulizia" nelle impostazioni. Da lì può selezionare la modalità personalizzata e scegliere la pulizia per aree specifiche.
UID:OP501831 IT
